Yes, the models can be edited. If you have the CAD model then that would be the best. An STL can be edited in software like MS 3D Builder.
Without actually seeing the model I can't tell much. Sometimes you can sink a model into the build plate in Cura leaving just the part you want to print. Then bring it back up and put a support blocker over the top part and just print the bottom. If you put a couple of matching 2.2mm holes in each part you can glue in pieces of filament to use as locating pins to align the parts when you assemble them.
GregValiant 1,318
