I have a file which cannot slice after resizing. Can anyone help?
Cura unable to slice please review settings and check if your models fit within the build volume are assigned to an enabled extruder are not all set as modifier meshes
- 1 year later...
GregValiant 950
Wow. Is that ever a mess.
There are 258 separate meshes assembled to make up the 4 wheels. The lug nuts are full of flipped normals.
In it's current form that "assembly" is not repairable (I tried) and consequently it isn't printable.
If you want to print those you will need to jump through some hoops.
- Load the Mesh Tools plugin from the MarketPlace. You will have to restart Cura after loading it.
- Load your model and select it.
- Right click and the top command will be Mesh Tools. One of the tools is "Split Models into Parts". Do that.
- Piece by piece delete one of the rear wheel assemblies.
- Piece by piece delete one of the front wheel assemblies.
- Right click and choose "Select all models".
- Cross your fingers.
- Right click again and choose "Merge Models". If it works the model may jump off screen. Select "Select all Models" and manually set the XYZ location so it's back on the build plate.
If that worked (it did on a single front wheel) then go to the Mesh Fixes settings and enable "Remove all Holes". Hopefully it will slice. This is without touching up the settings. It still needs a lot of work.
8 hours ago, GregValiant said:go to the Mesh Fixes settings and enable "Remove all Holes". Hopefully it will slice.
Remember to turn off this setting when you are done with this print. It is not a setting to leave on generally.
GregValiant 950
With your model selected in Cura - look to the lower left of the Prepare screen and you should see a circled (1) and a circled (2) indicating the extruders. Select (2).
In this image I have disabled Extruder 1 AFTER bringing the model into Cura. So the model is now set to a disabled Extruder. The funky cross-hatch pattern on the part indicates it won't slice. Selecting the circled 2 on the left will set the model to extruder 2.
