1 hour ago, ahoeben said:The profiles you create in Cura always reference the default quality profile you started with. Apparently in your case, you started with the "super" profile ("Super Quality"). That way, Cura combines what you set in the profile you created with the settings in the "Super Quality" quality profile. However, there is no "Super Quality" profile for the 0.6 mm nozzle variant.
If you want to experiment, you can change the default quality type your profile refers to by editing the .inst.cfg file in the "quality_changes" folder of the cura configuration folder. Look for where the file refers to "super" and change that to "standard".
Thank you!
From your information I understand understood how it works and my solution now is to add a .inst.cfg file for my printer for super quality and 0.6 nozzle and then my profiles shows up. However I'm a bit worried that the file I added will be removed in future upgrades - anything you know about?
To me, the correct solution would be to change the quality type "super" in the profile. But when I try to do that in the exported file I only get error messages while trying to import the changed file. Is there any way to change quality type in a existing profile?
ahoeben 1,718
