38 minutes ago, GregValiant said:With that model loaded and set up for a slice use the "File | Save Project" command and post the 3mf file here.
Something is going on at the root of the gear teeth at what looks to be the 9:00 position also.
Oh, and the Gear at the 9:00 position has a "cutout" due to a Tinkercad glitch in the gear generator. I've never been able to get it to make a perfect circle in the gear core but once printed there are no imbalance or shape issues.
GregValiant 951
Reddley 1
Here's another model with the same issue
Lego Beam Test.3mf
