3 hours ago, tinkergnome said:
- Just to be sure: these config files are for RRF 2.x or earlier - correct?
- The homing order on Ultimaker printers is: z-axis first and x/y afterwards (simultaneously) - which seems to be the case
- All endstops are configured as "active low" - which is correct (assuming RRF 2.x - the syntax of M574 is different for later versions)
- The content of "homeall.g" seems to be correct (IMHO)
- I think the current status of the endstops is to be seen on one of the duet web control pages (*) - you can check them manually one be one (trigger them by hand)
(*) Settings -> Machine properties- My best guess is a problem with the cabling
BTW: it seems you've mounted a Bondtech DDG feeder - good choice 🙂
Thanks. ^.^ Yes, those files were franken-steined from older sys files I found online for Duet 3D to use for Ultimaker 2. Changing some of the values to suit my setup (like the extruder).
I ended up researching different parts of the code in the config and homing files. While tinkering with the RRF config tool to try to match the values I saw in the code I saw in the frankensteined files. I ended up figuring out what needed changing in the end.
I just got a clean homing sequence an hour ago with a new set of sys files. Free of grinding noises and quiet. Well, as quiet as any 3DP with silent steppers I suppose. I tested the individual axes to double check it. No issues, thank goodness. The order now is X & Y then Z for home all. Which works for me.
I do appreciate the post. Thank you, and happy holidays! ^.^
Edited by rad_spider
tinkergnome 929
