The last E value before that line is E119.0943 and so that move to E112.5943 is your normal "Retract Distance" and doing a little math it is 6.5mm. That is the normal situation when retraction is enabled in Absolute mode. In your second example the E3768.34114 is probably "Retract Distance" less than the previous E value in that Gcode file. Assuming that your retract distance was 6.5 for that file, that would make the previous E value 3774.84114.
This is the Ending Gcode used by a lot of Creality printers. It will work on your Anet.
When Cura finishes calculating the Gcode it will add that final retraction...call it 6.5mm. The code below will retract an additional 4mm and so at the end of a print the filament will be 10.5mm back from the nozzle. That would need to be taken care of either by adding purge lines to the StartUp G-Code, or making sure a skirt/brim is long enough to "take up the slack".
GregValiant 1,318
;Ending Gcode
G91 ;Relative positioning
G1 E-2 F2700 ;Retract a bit
G1 E-2 Z0.2 F2400 ;Retract and raise Z
G1 X5 Y5 F3000 ;Wipe out
G1 Z10 ;Raise Z more
G90 ;Absolute positioning
G1 X0 Y{machine_depth} ;Present print
M106 S0 ;Turn-off fan
M104 S0 ;Turn-off hotend
M140 S0 ;Turn-off bed
M220 S100 ;reset feedrate
M221 S100 ;reset flowrate
M84 X Y E ;Disable all steppers but Z
;End of the End Gcode
