Posted
· CURA slicer, gaps between inner walls and infill
Zooming in on the photo of the 4 gears they are 15 to 20% under-extruded. Before you start changing other settings I think you need to address that. The center walls of the hole for the shaft look more like hex's than circles. I think that's because the plastic wasn't getting smashed down and instead it was dragging in towards the centerline of the hole.
This is your photo. I've added some red lines where there is under-extrusion. Fixing it might be as simple as calibrating the E-steps. It could be other things as well but that's where I'd start.
GregValiant 1,342
