GregValiant 1,342
Are there some Gcode or Mcode commands in Klipper that differ from Marlin? I've read that Enders equipped with Klipper will run Gcode sliced for Marlin.
Dim3nsioneer 558
Since none of the Ultimaker printers runs with this specific firmware it would be a community job to add it since Cura is open source. Maybe you want to suggest it directly on Github or even provide the necessary code there? 😉
