Ultimaker 2+ turns off right after strting the pre heat/print
Tribomar2022
Posted · Ultimaker 2+ turns off right after strting the pre heat/print
when starting a print with the UM2+ from cold the machine doesn't start the print process but restarts the whole system. the bug occurs only with new gcodes; an old gcode, from about 4 weeks ago, works with no problem.
When I start with the old gcode, abort after a few minutes heating and start the new gcode it works fine, so this is a workaround.
I just updated the firmware thethe bug persists.
does anyone have a solution to this bug?
all the best 🙂
    So we have to inspect both an old an a new gcode file. The first ~50 lines of code from each will suffice. Please upload them somewhere and post a link (dropbox, google drive, wetransfer etc)
    Posted (edited) · Ultimaker 2+ turns off right after strting the pre heat/print
    The difference between the two is that in the old gcode, first the bed is fully heated up, and then the extruder. In the new gcode, the bed and extruder heat up at the same time. What is likely happening is that the power supply does does not have enough power to heat the bed and the extruder at the same time; keeping the bed or the extruder at a high temperature costs less power than heating up from cold. When the power supply "runs out of power", the printer electronics also get less than they need, causing the printer to reset.
    To be honest, I don't know why this was changed. Did you tweak the start gcode in Cura? If so, undo those changes.
    Edit: wait, is this even Cura gcode?
    Edited by ahoeben
    • Thanks 1
    I didn't do anything with the code. so far I did all the drawing and slicing with Fusion360 and didn't have any issues. I will try to find where is cane from and change it.
    However, thanks for the helping to find the bug, the explanation is simple and plausible. Great work!
    Edited by Tribomar2022
    ok, I checked it, Cura-gcode works no problem...
