Posted · Temperate Problems
Hello,I have an A20M 3D Printer and I'm using Cura for the controls. It's a dual extrusion printer as well.
I'm trying to make use of the dual extrusion feature but I keep running into issues related to the temperature. When it's printing from Extruder #2 the temperature changes for seemingly no reason. I have the material temperature set to 200c and yet I see it changing the print to 185 and 195 throughout the print, disrupting things in the process. I can't figure out what's causing it.
GCode for the print attached. Thoughts?
Test.gcode
