I'm having the exact same problem. Have you found a solution? I've found that you don't need to remove the Bowden tube or cut anything. Just let the core heat back up.
Sadly i didn't find a solution - now I even have the problem occurring with another Filament - Polymaker PA6-CF.
I remove the tube so the Feeder doesn't Push the Filament through the nozzle with the wizard. Then it can be unloaded.
The print bed also falls down after the wizard finished.
What i did is replace the front fan because i thought the filament gets stuck in the tube of the core.
Nothing changed - the printer seems to make a cold-pull but can't do it because the PA is too sticky.
Is there a way to override this cold pull?
It's not very efficient when i have to remove the filament manually after every print - if i wanted to do that i could have bought a much cheaper printer.
dcschooley 9
SchraubenPhil 1
