QUESTIONIs it possible to have both AA25mm and AA40 print cores installed at the same time?
Posted
· Is it possible to have both AA25mm and AA40 print cores installed at the same time?
Yes, that is certainly possible. Each extruder has its own profiles. If you want to select a profile for the second extruder, you have to select that extruder above the setting list.
One thing to realise is that because Cura generally can not "mix" different layer heights in a single layer, both extruders will need a profile with the same layer height. This limits the available profiles of you mix two different extruders. You can get around this by going in the extruder configuration in Cura and disabling the extruder you don't use.
ahoeben 1,723
