Right now, I'm using 4.13.0 Beta, but had the same issue with the previous version, 4.12.1,
I'm using a stock Ender 6, but with a Capricorn Bowden tube, and Overture 1.75mm white PETG.
Here is the .gcode file of a 20% XY scaled version of the part, but with 100% Z. This makes it easier to test.
I'm not sure what I'm actually seeing, but it almost looks like the travel speed multiplies the print speed. Changing the travel speed makes a difference, but changing print speed makes a bigger different when the travel speed is high (100-150), but only when it's printing the infill.
GregValiant 695
What version of Cura?
I read your other post BTW. The travel speed should not be related to the infill speed. It isn't in my installation of 4.12.1 at any rate.
Post a gcode file that shows the problem. Let us know what printer as well.
