Print sequence is only enabled if you have a single extruder active. If your machine has multiple, disable all but one and the setting should become visible.
Yes i know where the setting is, i am wondering why it is disabled with dual extruders, technically this setting should work fine with dual extruders in duplication or mirror mode.
Because Ultimaker doesn't have printers with duplication / mirror mode. As such, we never spent time on implementing that. Unfortunately, the companies that do use Cura and have IDEX systems never contributed their changes back.
that sucks, IDEX is really nice.
I suppose i could make a custom machine with 1 extruder and same bed size info use the feature and the idex will figure out the rest. Ill test
GregValiant 989
It's under "Special Modes" and the setting is actually called "Print Sequence". The options are All at Once or One at a Time.
