Thanks for your reply, Geert. The examples are printed with high quality PLA, which I have dried for 6 hours at 40 degrees celcius before printing. I have enabled retraction in the slicer prior to printing as well.
As far as the printing speed goes, I do not think it would solve the stringing issue, as it only occurs during travel movements. Perhaps changing the travel speed would help?
I see your point in regards to the first layer. The print actually has a bit of an elephants foot - wouldn't that be due to the nozzle being too close to the bed, under normal circumstances?
15 minutes ago, geert_2 said:Also, not sure, but the vertical patterns in the benchy might be infill shining through?
Unfortunately the pattern showing on the surface is inconsistent with the filling pattern, so I am not sure why it appears. I just corelate it to the stringing issue.
BR
Oliver
geert_2 556
Is that material PLA? Some materials do string a lot more than others, e.g. the PET I have, because they are more elastic, while molten PLA is more like yoghurt. So, if it would not be PLA, try PLA first, with a fairly standard speed of 50mm/s.
I never played with retraction settings, so I can't say anything on that. Did you enable retraction in the slicer, make sure it is not switched off somewhere (there is a checkbox in my Cura version)? Forgetting to enable retraction would cause the same stringing effect.
Also, it looks like your nozzle is too far away from the glass: normally the bottom layer should be much smoother, more squeezed agains the glass.
This is how the bottom of my prints usually looks for normal prints, and for very fine prints:
