GregValiant 989
You still may find that the speed is limited by the printer itself. From looking in the definition files the Max Feedrate in Cura for the X and Y is set at either 100mm/sec or 150mm/sec depending on the model. What the Max Feedrate is in the printer is listed in M203. You might be able to view it on the LCD or my sending M503 and looking at the printer response.
If you add M203 X500 Y500 followed by an M500 to the start of a gcode file you can pretty much insure that you won't bump up against the speed limit.
(I doubt that TronXY would have limited the speed without a good reason.)
1
Filmpalast 2
OK habs schon, Printer Settings
