Dankeschön, das mit dem Log sollte schon mal helfen.
Die müßten im Konfig- Ordner abgelegt sein. Muß da aber auch nochmal nachsehen.
Die Dateien sind schon mal richtig abgelegt.
Das Log gibt folgende Fehlermeldung in vielfacher Ausführung aus.
- ERROR - [MainThread] UM.Settings.ContainerStack.deserialize [429]: When trying to deserialize Hands 2, we received an unknown container ID (Hands2)
2022-01-22 21:10:45,702 - ERROR - [MainThread] UM.Logger.logException [112]: Exception: Error in the format of container Hands 2: When trying to deserialize Hands 2, we received an unknown container ID (Hands2)
2022-01-22 21:10:45,704 - ERROR - [MainThread] UM.Logger.logException [116]: Traceback (most recent call last):
2022-01-22 21:10:45,706 - ERROR - [MainThread] UM.Logger.logException [116]: File "C:\build\Cura\4.12-exe\build\inst\lib\python3.8\site-packages\UM\Settings\ContainerRegistry.py", line 215, in findContainers
2022-01-22 21:10:45,708 - ERROR - [MainThread] UM.Logger.logException [116]: File "C:\Program Files\Ultimaker Cura 4.12.1\plugins\LocalContainerProvider\LocalContainerProvider.py", line 79, in loadContainer
2022-01-22 21:10:45,710 - ERROR - [MainThread] UM.Logger.logException [116]: container.deserialize(f.read(), file_path)
2022-01-22 21:10:45,712 - ERROR - [MainThread] UM.Logger.logException [116]: File "C:\build\Cura\4.12-exe\build\inst\lib\python3.8\site-packages\cura\Settings\CuraContainerStack.py", line 309, in deserialize
2022-01-22 21:10:45,713 - ERROR - [MainThread] UM.Logger.logException [116]: File "C:\build\Cura\4.12-exe\build\inst\lib\python3.8\site-packages\UM\Settings\ContainerStack.py", line 430, in deserialize
2022-01-22 21:10:45,715 - ERROR - [MainThread] UM.Logger.logException [116]: UM.Settings.ContainerFormatError.ContainerFormatError: When trying to deserialize Hands 2, we received an unknown container ID (Hands2)
Den Pfad "C:\build\Cura\4.12-exe\build\inst\lib\python3.8\site-packages\cura\Settings..." finde ich nicht. Es gibt kein C:\build.... auf meinem Rechner.
Die Zeilen der LocalContainerProvider.py um die Fehlermeldung: ERROR - [MainThread] UM.Logger.logException [116]: File "C:\Program Files\Ultimaker Cura 4.12.1\plugins\LocalContainerProvider\LocalContainerProvider.py", line 79, in loadContainer
Da hab ich keine Ahnung was da falsch ist.
Ich würde dem hier mal nachgehen:
Sieht für mich so aus, als gäbe es Dateinamen mit einem Leerzeichen dazwischen"....Hands 2....", in der Datei steht die ID (bzw. "name") aber ohne Leerzeichen "Hands2". Oder umgekehrt - da passt irgendwas nicht zusammen.
Wobei: Cura selbst scheint keine Dateien mit Leer- oder Sonderzeichen im Namen anzulegen, das wird jeweils ersetzt. Da steht dann z.B. sowas wie: "....Hands+2..."
Das scheint auch irgendwie wichtig zu sein...
In kurz: Ich glaube, Du machst Dir das (Cura-)Leben einfacher, wenn keine Leerzeichen im Druckernamen vorkommen.
Oder wenigstens überall die gleiche Schreibweise, und die Dateinamen müssen jeweils dazu passen.
Edited by tinkergnome
Danke, für den Hinweis, das ist mir nicht aufgefallen.
Wie schon geschrieben habe ich die Dateien einfach aus der Konfiguration von der beim Hands2 mitgelieferten Cura Version kopiert.
Edit:
Bin die ganzen Dateien durchgegangen, hab die Leerzeichen entfernt, keine Änderung.
Hab dann an allen Stellen wieder Leerzeichen eingesetzt, dann startet Cura nicht.
Hab den Drucker jetzt rausgeschmissen, Cura läuft, keine Fehlermeldung, aber halt auch der Drucker nicht mehr nutzbar.
Leider übernimmt Cura bei einem Update nicht die Drucker aus einer 2. alten Installation.
Mal schauen wie ich da weiterkomme.
Danke für die Hilfe!
Edited by TTX380Hab die mitgelieferte Cura 4.10.0 installiert. Der Hands2 läst sich auswählen und benutzen, sowiet alles OK.
Dann das Update auf die Cura 4.13.0, Drucker ist weg, Fehlermeldung ist da. Die Tenlog Drucker sind auch nicht auswählbar.
Ist jetzt eindeutig ein Fall um den Support von Tenlog zu testen.
Edit:
Mit der 4.11.0 wurde entweder eine Überprüfung, oder eine Änderung der Druckerdaten eingeführt.
Ab der 4.11.0 funktionieren die Tenlog Drucker nicht mehr.
Edited by TTX380
tinkergnome 929
Ein wichtiger Punkt ist: Wenn Du eigene Druckerkonfigurationen hast - lege sie im Konfigurationsordner der jeweiligen Cura-Version ab - nicht im Programm-Verzeichnis.
Sie werden dann automatisch kopiert und ggf. angepasst, wenn eine neue Cura-Version installiert wird.
Wenn das aus irgendeinem Grund nicht klappt, müsste es Hinweise auf den konkreten Fehler in der Log-Datei geben.
"cura.log" - liegt ebenfalls im Konfigurationsordner.
Der Pfad zum diesem Ordner hängt vom Betriebssystem ab. Mit dem Menüpunkt aus dem Screenshot unten sollte Cura an die richtige Stelle navigieren. In den diversen Unterordnern liegen vermutlich die "beanstandeten" Dateien aus der Fehlermeldung. Dort können sie auch einzeln korrigiert (oder gelöscht) werden.
