Weird slicing issue
rwalker43
Posted · Weird slicing issue
I'm using Cura 4.11.  I created a model in Fusion 360, which is a platform with text horizontally on the top.  When I slice the model in Cura and look at the layer view, the model has a total of 43 layers.  The text begins printing at layer 30, however, Cura starts part of the text at layer 27!!  When viewed in the slicer, this appears as two little dots.  When the model is printed of my Ender 3 Pro, the surface of the print has irregular lines between the edge of the print and those dots.  The text I am printing begins with an uppercase M.  Those two dots line up with the top of the verticals of the letter.  Any suggestions?  I have printed this model using Prus Slicer, but not had this issue.  Any help or direction would be greatly appreciated!
    Posted (edited) · Weird slicing issue
    In the "Top/Bottom" settings - set the "Skin Removal Width" to 0.1.
    Cura is removing the "skin" from under the letters where the letters are wide enough that the "skin removal width" would apply.  If you look close you'll see that the "M" in particular has wider parts at it's points.
    For a comparison - set the "Skin Removal Width to 2.0 and see what happens.
    Edited by GregValiant
    Experience with such things.  These on my single extruder printer.  The windows and curtains on the trailer/sleigh were glued on.
        • 24 replies
