I think the 2015 should be removed, it's been a long time since we actually build with that.
From the article:
Microsoft Visual Studio 2019 (recommended install)
When I tried to build with 2022 I had therefore to install MSVC v142 -- 2019 which you have unchecked.
nallath 1,063
"Unsupported MSVC version"
The problem seems to be that you're using a compiler that isn't supported. It's been a while since I created a setup for windows, but it seems that you're using MSVC 2022, whereas the instructions indicate that you need to use the 2019 version.
ZacharyHowell 0
Perhaps I'm not looking in the right place, but it almost seems like even though I have "MSVC v140 - VS 2015" checked in the installation details, it doesn't seem to be installed.
