1 hour ago, GregValiant said:This was a problem in 4.11 on single layer prints. So far as I know it was fixed in the later versions. I can't duplicate this in 4.12.1. You are sure that the bottom of the model is at Z= 0?
You can try adjusting the layer height to .099 and see how it goes.
I'm on 4.13.0, so by all accounts shouldn't happen. Decreasing the height to 0.099 did bump the print up to two layers, but still not the expected 3.
And yes, it is at zero:
And here you can also see the part is placed on the surface. Nothing below the surface plate line.
Edited by NMGMarques
GregValiant 1,490
