GregValiant 700
@AmberElferink if you would post the 3mf file here someone will take a look. It's the best way to transfer the model and your settings.
Edited by GregValiant@AmberElferink if you would post the 3mf file here someone will take a look. It's the best way to transfer the model and your settings.
Edited by GregValiantI turned off "Retract Before Outer Wall" and changed the combing mode to "All". Take a look.
Thanks for having a look @GregValiant.
I found the following: loading your file with all your settings and pressing slice once gives the correct output.
Just to distinguish the exact settings, I changed back to my old profile and tried to enable the differences between our profiles one by one.
Retract before outer wall did not make a difference.
Neither did some 4 other settings that were different.
What did give the correct result only compared to my previous try are these two settings:
- setting combing to "all"
- reducing the line width from 0.4 mm to 0.35 mm. (without this it still gave the same issue).
I am confused as to why it works, but I'm happy that works. I feel this is some form of bug, but at least I can work with it for now. Thanks a lot!
Edited by AmberElferinkIt might be a bug. 4.12.1 and 4.13.1 seem to be fussy when the line width and the model wall thickness are exactly the same. Sometimes it's because a round model isn't really round and the facets of the triangles that make up a curved surface in an STL can't be "concentric" and so the thickness varies by small amounts. It might also be a "rounding off" thing in the internal math in Cura. I'm guessing here as I don't really know.
On that particular model, MS 3D Builder found a minor error but it didn't seem to affect slicing. The model is of high enough resolution that I don't believe there should have been a problem - but there was.
AmberElferink 0
Apparently this was fixed in Cura 4.13.1. EDIT: When I uninstalled and reinstalled the new version for some reason it worked fine (I kept the configuration files). However, when I changed my model just a bit (increasing hole sizes) it was directly back to its old behavior. I don't know what to do anymore.
Edited by AmberElferinkLink to post
