preparing G-code
duiker2106
Posted · preparing G-code
To A. Hoeben
I did the slice, but that didn't work either (see picture)
It fits in the printing space,
Assigned to the extruder I have
No idea what is meant by "set as modifier meshes"...
In short.. help!
    See that pointy gray "shadow"? That needs to fit inside the build volume. The model is striped to show that Cura thinks it does not currently fit inside the buildvolume. There seems to be a "stray" point or piece of geometry in the file. Can you post a link to the model?
    I got the design from Thingiverse.
    but I guess that I can place it correctly by replacing it on the plate.
    to be continued…
    IT WORKS!!
    The print is being made at this moment!
    Thanks for the help👍🏼
