in the UM3 it should indeed be possible to never use active leveling, so indeed set it to Never AND also run the manual leveling procedure once after doing so.
It might also be better to do a factory reset/reset all settings before you do any of this so that old data can't block this from working.
glx 15
To prevent it from active levelling before every print, you can set the active levelling frequency to 'never' in the options of your UM3.
To get it back working first check the cable in the back of the print head. You can see it, when you open the front fan door, it's a red/blacl cable in the back that connects to the bottom part of the printhead-door. That cable can break after a while (mostly from opening and closing the printhead often to change the cores. The cable is a 5ish Euro spare part and it can be replaced in about half an hour if you have never done it before (and way less if you already know the procedure).
