Posted · Update standard profiles
Hello together,
Does somebody know a way to Update die standard profiles in cura in the aplication ?
Only way to do this i see is to copy the original printer config .json file write it in there and import the new printer ... it works but its not very user friendly ...
Why because many will change something on there printers or have their own preferences what will make the standard profiles complete unusable !
I my case i changed from bowden extruder to direct drive so the settings for retraction in the standard profiles cant be used anymore so everytime i have to choose a other profile and have the standard profiles as trash profiles in the application.
I solved it as i said with write the changes  in a copyed printer profile .json and add the new printer now i have the changed retraction settings and so on in the standard profiles and they work again. But in my opinion its not very user friendly.
I could be relative simple for everyone to improve their standard profiles if the option "Update Profile with the current settings" would also be enabeld in this Profiles.
Because i think everyone has their own standard needs or preferences for a standard profile and not only this what the application mean that should or in this case must be their standard ...
Thank you
Patrick
