An off-topic tip, as a reaction to your screenshot:
It looks like you have the option "Origin at center" checked in the machine settings, but you don't have a delta-style printer. It is fairly unlikely that your firmware actually has its origin at the center of the buildplate. So unless you are getting prints in the location where you expect them with your current configuration, you may want to uncheck the option "Origin at center" in the Machine Settings (on the Printers pane of the preferences).
1
nallath 1,067
It only works if you're not running in compatibility mode. You are. This can either be because you enabled that in preferences or because your GPU doesn't support the extra features that we need.
