Printing Failure for Disc
Sen_Kev
Posted · Printing Failure for Disc
While trying to print a disc (D=77mm, H=3mm), failures below kept occurring.
1. Material has a hard time sticking onto the build plate resulting in initial layer deviation.
2. Printed product is warped due to insufficient adhesion between build plate and initial layer.
I have attempted the following measures but nothing worked:
1. Using glue stick on build plate (Glue dries up very quickly, not sure if it's supposed to be like that).
2. Altering build plate temperature between 60-75 degrees Celsius.
(P.s. Build plate is cleaned after each printing.)
Is there a specific setting that needed to be followed for this?
UM2C_Disc.stl UM2C_Disc.ufp
        • 27 replies
