Hi, Manuparis
I do it manually during printing.
1. Install DUPLICATE extension from Marketplace.
2. Duplicate Extruder 1 to Extruder 2.
3. Slice
4. Preview. A slider appears on rh side.
5. Slide up and down and read the layer you want.
6. Start printing and see Z layer on the screen.
7. At the chosen layer, press once, Mixer, Toggle Mix.
tinkergnome 917
Usually it's done with two separate models - one for each extruder - that are arranged with the "merge models" function.
https://support.ultimaker.com/hc/en-us/articles/360011738340-How-to-merge-and-group-models-in-Ultimaker-Cura
For a single model one can make use of one or more "modifier meshes" to achieve the same, like described here:
https://support.ultimaker.com/hc/en-us/articles/360013370140-How-to-adjust-print-settings-of-a-part-of-my-model-in-Ultimaker-Cura
BTW:
If you don't have an according modifier model at hand - you can "misuse" a support blocker for this purpose. Just add one to the model, change the type to "Cutting mesh", scale and position it to your likings and choose an extruder.
