My problem has changed since I last posted to one bad PT100 sensor. The bad sensor now reads in the 500s only.
A quick update:
- I rolled back the firmware on my Duet 2 wifi to 2.05. I may update that all in the future, but for now I'm using it to better match my config file version made by the RRF tool.
- I checked for loose connections to the daughterboard. Found one. Put it back in and tightened it. Got a good reading at that point, it just turned out to be for the wrong heater. I then tinkered with the config file when I realized the sensors were backwards. The bed sensor is the one that works. The nozzle sensor, I have no idea what is going on. It now reads in the 500s (pic posted below).
QuoteAlthough M305 still seems to work - for RRF3 one should use M308 instead.
(according to the documentation here: https://docs.duet3d.com/en/User_manual/Reference/Gcodes)
Here's an example that seems pretty close to your setup:
https://forum.duet3d.com/topic/19386/pt100-sensor-and-daughter-board-issue
Out of curiosity: for which printer do you use the Duet Board?
Thanks. It's a Ultimaker 2, modified with a BMG extruder.
My issue is starting to look hardware related now. Although I don't think it has anything to do with length of the wire or it's diameter (in the PT100 troubleshoot section), since the bed sensor wire should be similar (at least after rewiring everything last year). I work on this printer periodically if anyone was wondering why there's such a gap between now and then.
Although I'm not sure where the current issue is. It could be a bad connection. The sensor itself? The point of the wire that's spliced? The ferrule tips used for the terminal? Something else? *sigh* I guess I'll explore all these one by one. Maybe I'll find the solution.
But if there is better advice, I'm open.
Edit: Snipped off the old ferrules and replaced them on the nozzle sensor wire. Not the issue. Will resume trying to find the cause tomorrow.
Edited by rad_spider
tinkergnome 924
