22 minutes ago, Rootpass said:Will it be added?
That depends on if someone will contribute a printer definition for it.
Ultimaker only creates printer definitions for its own printers. All other printer definitions are contributed by 3rd parties; either printer manufacturers, or community members.
2
GregValiant 696
The definition is very close to the A20T. You can add an A20T and change the name on the right side of the "Add" dialog box. After adding the printer go to "Manage Printers / Machine Settings" and change the build plate size. I believe the numbers for yours are X320 Y320 Z400.
The next Cura release may have the Geeetech A30T definition.
