4 hours ago, ahoeben said:It could be that Cura does not properly handle the space in your username. To confirm that this is the issue, you could try creating a new user on your computer that does not have a space in its username and run Cura as that user.
Thank you very much ahoeben.... that was the problem ...........thank you .....thank you.
- 1
ahoeben 1,955
