SolvedHow to get cura's time estimates closer to reality?
Posted
· How to get cura's time estimates closer to reality?
In this case it appears to be something in the Settings Profile but I'm unable to find it. Simply opening your 3mf file and slicing it I get a print time of 4:47.
Just switching to the Standard Settings profile (with infill adjusted to be the same as your settings) the print time drops to 3:09. Switching the infill to Grid results in a print time of 1:54.
So maybe something is going on with that settings profile, or maybe with the Creality Ender 6 definition or the Creality Quality files?
As an experiment - try using a stock profile like Standard/Draft with 20% Grid infill and see if it makes a difference.
The Grid infill results in a few lines of gcode. The Gyroid infill results in a bazillion lines of gcode because of all the curves. Part of what is going on may be a cumulative error when Cura attempts to add up the print times for all those short line segments. I have no idea if that may be true or not but in this case we can see that Grid v Gyroid makes a big difference.
This topic comes up a lot. For myself, the Cura estimated time versus the real print time is consistently within 12% of each other and Cura always over-estimates.
Posted
Thanks for looking at this.
I've now created a new profile, just copied the speed and accel settings into it, tried a few things and yes, they are indeed a lot more accurate now. Nearly spot on.
Very interesting.
I'll simply on from this new profile.
1
I'm excited because I've personally produced this showcase event, so if you are curious what else I'm up to nowadays, come check it out and say hi in the chat! It would mean a lot!
GregValiant 697
widden 2
Very interesting.
