GregValiant 1,287
Your settings look reasonable. I would suggest that you keep all the speeds closer together. When you constantly bounce the printing speed up and down then the pressure in the nozzle varies from "this area" to "that area" and you can get some visual blemishes. In particular is that area of the outer wall at the start of the extrusion. The nozzle is moving CCW and one problem may be the initial surge as the extrusion starts. It seems to take around a 1/4 of the way around before things settle down - and then it does it again on the next layer. Some layers are a tad worse than others.
If you are confident that there is no wheel problem, no dirty trolley tracks, and nothing is loose (like maybe the hot end? For me it's often the last thing I worked on.) then consistent flow rate is something you might think about.
For the upper part - your layer cooling may be better than mine as I can't do a 3 second layer time without some consequences. If the layer below hasn't hardened and I squish more hot plastic down on it then it can leave (barely) noticeable differences in the layers.
In the image - the one with the brim is a slice of your 3mf file. The only change I made was the infill density down to 10%.
The other print is also at .15 layer height but is with the outer wall at 35mm/sec, everything else at 50mm/sec, 3 outer walls, and minimum layer time at 10 seconds (resulting in the top "chimney" portion being much slower).
With your settings I can see some bouncing at the start of the outer wall extrusion that results in a more noticeable Z seam. The extrusion does appear to take a few mm's to settle down. By the time it gets back to the start point it's fine.
The bottom line here may be that the print I set up took 37 minutes and the print you set up (with infill at 10%) took 20 minutes. There are advantages to slowing down. Using PLA I typically print small things at 50 with 35 outer wall. For large prints I may go to 100mm/sec with the outer walls at 50. There is a definite trade-off of quality vs speed.
The attached gcode file is with my printer (Ender 3 Pro) and my settings. I have adjusted the temps to match your preferences. It should print fine on your Tarantula (if you want to give it a shot).
- 1
GregValiant 1,287
The vertical line on the rear is likely the Z seam. It's where the outer wall extrusion starts and stops. You can't really hide it on round parts. There are settings to move it around and one of the settings is "Random". To me that just looks like zits all over.
If you changed the thermistor along with the hot end - did you run Auto-Tune to adjust the PID settings? The new thermistor is likely different than the one you replaced.
To pass your settings and the model over: With the model loaded and Cura set up and ready to slice, use the "File | Save Project" command and post the 3mf project file here.
Megiddo 1
Cool thanks. I will change it to Random for future round prints. I also ran Autotune PID for the hotend 3 times using the C3 command and input and saved those recommended settings inside the config file. I have attached the 3mf file
TT_ResMed 10 Adapter.3mf
