@ahoeben: yes they are white for the ultimaker 2+connect and the S3 and yes they are in place.
But thanks for your response
Normally the clip is the trick. You could try with this thicker clip:
https://www.youmagine.com/designs/ultimaker-bowden-clip-thicker-version
Thanks @ahoeben, i will give this a go
That clips seems excessively thick to me? But if it works...
I would rather think the white colar would be the problem, the metal inserts not clamping enough?
But if you expect the horseshoe-clips to be the problem, you could also try my old design. Although its bottom plate has about the standard thickness. If you want it to be thicker, maybe rescale only in the Z-scale? Or edit the design and make the bottom plate thicker. This clip is way easier to mount and remove than standard clips. I remove it every few days to change filament colors and to clean the nozzle with my more gentle "atomic pulls".
Print it slow and in thin layers. Print cool to prevent decomposing from sitting too long in the nozzle, and print multiple models at the same time, to prevent overheating and sagging of the model. I would go for 0.06mm layer-heigt, 20mm/s, and 190°C for PLA or 210 for PET (shown below in red), but your materials may vary from mine.
See my personal page for the CAD-files: https://www.uantwerpen.be/nl/personeel/geert-keteleer/manuals/
If you like any of these, download them to your own computer. It is not sure that I can keep them up here.
ahoeben 1,986
You mention the tube and collars, but is the clip that should pull the collar up a bit in place?
(the blue parts in the image above; they are normally white on an S3)
