I removed all of the build plate adhesion but this still didnt change the fact Cura wouldnt print it, i'll have a look through the article when home from work. Thanks
Did you ever figure this out? I’m having this exact problem.
7 minutes ago, mattjugan said:Did you ever figure this out? I’m having this exact problem.
If you could post a Cura project file (.3mf, in Cura go to File > Save Project) that has this problem so we can have a look at it that would help. This is a pretty old thread so it's possible you have a newer, different problem.
22 minutes ago, Slashee_the_Cow said:If you could post a Cura project file (.3mf, in Cura go to File > Save Project) that has this problem so we can have a look at it that would help. This is a pretty old thread so it's possible you have a newer, different problem.
See attached. Any help would be greatly appreciated!
That file only seems to contain the model - you need to set it up like you were about to print it (if you could) and then choose Save Project. Some people accidentally pick Export which isn't what we want.
54 minutes ago, Slashee_the_Cow said:That file only seems to contain the model - you need to set it up like you were about to print it (if you could) and then choose Save Project. Some people accidentally pick Export which isn't what we want.
Sorry yes I initially chose export, but attached below is the normal Save Project
10 hours ago, Slashee_the_Cow said:
Thank you so much! As you can tell I'm very new at all of this, and I'm not sure how the object got a negative z value but I very much appreciate your help. I am back up and running! Thanks again
ahoeben 1,981
Cura reserves space around the model to be able to print the brim or skirt you have selected and other things. Here's an elaborate article about that: https://support.ultimaker.com/hc/en-us/articles/360013799339-How-to-print-the-maximum-build-volume-in-Ultimaker-Cura
