Thanks for finding this post ! I somehow feels as being a noob since I hacked printers for a full decade. Actually I specifically bought the UM3 with the promise I would never open it, but, well, I have a good reason now 😝
Will tell in a few days tho, I am far from it right now. Thanks again for the pointer, looks promising 🤞
ultimaker UM3 wifi dead ? (hardware not even registered in dmesg)
Back on the printer. Sadly, no, mine is firmly connected, with its screw to hold it in place. I obviously tried to disconnect and reconnect it without improvement.
I am now looking for the board pinout (no silscreen), because I could try to find another wifi card.
I would probably not even look for the official one since whatever comes from Ultimaker is outrageously expensive, and it does not prove reliable in my case. No word either from the official support as shown here.
To the least, I am pretty disappointed 😢
Oh I found some replacement : 160€ ! This is utterly ridiculous.
Or $110 at some third party's while the Olimex board is $330, this can't be serious 😕
more about prices
For the record I tried some wifi dongle, in hope linux would see it. Sadly no (one of the logs below).
I can't keep on trying, what a pain.
[ 18.248609] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5390, rev 0502 detected
[ 18.329749] lm75 3-004f: hwmon0: sensor 'lm75b'
[ 18.381941] uvcvideo 2-1:1.0: Entity type for entity Camera 1 was not initialized!
[ 18.591286] input: USB 2.0 Camera: USB 2.0 Camera as /devices/platform/soc@1c00000/1c1c000.usb/usb2/2-1/2-1:1.0/input/input5
[ 18.839838] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5370 detected
[ 19.160846] usbcore: registered new interface driver uvcvideo
[ 19.166622] USB Video Class driver (1.1.1)
[ 19.468007] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 19.489514] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
[ 19.499318] usbcore: registered new interface driver rt2800usb
[ 19.509679] rt2800usb 5-1:1.0: Direct firmware load for rt2870.bin failed with error -2
[ 19.517744] ieee80211 phy0: rt2x00lib_request_firmware: Error - Failed to request Firmware
[ 21.348000] usb 2-1: reset high-speed USB device number 2 using ehci-platform
[ 22.597119] rt2800usb 5-1:1.0 wlan1: renamed from wlan0
- 2 weeks later...
Sadly, these wifi modules do sometimes break down. More info in my post:
You already tried other WiFi modules. I didn't check, but be aware that the Linux version in the UM3 printer is Debian Jessie, i.e. from 2015. Look for older WiFi models.
Other paths to try:
- Find another WiFi usb-module with the same chip (Atheros AR9271), costs about $19. The internal Olimex board has a spare USB port, except that the connector is a different type. Try the external USB connector first for testing.
- Add an external WiFi access point on the LAN cable
1
Enigma_M4 74
possibly this thread might help?
Regards
