could the Z seam not be better hidden by beginning an extrusion on the innermost inner wall then wrapping around (in a continual extrusion) until the outer wall is enclosed? Then the Z seam would be hidden inside of a print (with the exception of the top-most revealed layer).
Z-seam is a bit of a misnomer. If you do what you suggest, you still get a seam, where the toolpath goes from the outer wall to the inner wall.
My z-seam appears to only occur when "starting", not oozing from ending a layer. I've been changing settings to minimize the seam, but it seems the underlying issue is the lack of continual movement - and resolving that (at least on the outer wall) would be the ideal solution. Of course, if the nozzle was continually moving like in the picture, the prints would also complete faster.
For reference, I'm running linear advance and all other speed changes are working as I'd like - this z-seam (coming from the initial extrustion when a layer starts) is the only remaining quality issue I'm unhappy with.
I could be mistaken, but it seems that (at least in my situation) the underlying issue is the lack of continual movement, which I would love to be able to address. Does this sound right?
I'm excited because I've personally produced this showcase event, so if you are curious what else I'm up to nowadays, come check it out and say hi in the chat! It would mean a lot!
ahoeben 1,586
Jagetsu 0
