Posted (edited) · Change top surface direction
Hello Ultimaker community,
  I am experimenting with increasing, improving and optimizing 3d prints strength and finish. What I was wondering if there was a way to set the top layer to a deposition pattern different from the underlying layers; similar to the way you can set the bottom layer initial pattern separate from subsequent layers? Specifically referencing something like "line" to "concentric", vice versa or different combinations (with "line/zigzag", "zigzag/concentric", etc.)
  I know changing layer line direction/angles is possible per alternating layers, but going from line to concentric at the top layers (or in any) isn't available that I could find.
  If it isn't currently possible to change layer patterns per layer (other than the aforementioned way) I think I would be a easily implemented, and welcome, addition; that would add a increase to the structural strength of prints.
  If this is already possible could someone please instruct me?
  Thank you in advance for any help,
Patri0t
Hobbyist/Enthusiast !.5 yr 3d print exp
Ender 3 Pro (multiple performance and stability upgrades)
Cura 4.13.1
OnShape
Fusion360
TinkerCad
Pronterface
Edited by Patri0t
additional info
    Posted · Change top surface direction
    When you set the "Top Surface Skin Layers" to a non-zero number then the "Top Surface Skin Pattern" becomes available in the Experimental section.  The options are Lines, Zig-Zag and Concentric.
