8 minutes ago, gr5 said:You need a much denser pattern as you get close to any top surfaces. To support these surfaces from within the
Right, it's about the pattern, not that specific image/design. Since the amount of infill between the walls can use existing infill patterns pretty much.
The 2nd example shows what a 3D design may look like. But a lighting infill example would look something like this, with 2 walls eliminating the outside seam, otherwise you can build up the bumps wherever needed to fully support a roof, just like lighting infill.
https://imgur.com/0yUMlNk
gr5 1,841
You need a much denser pattern as you get close to any top surfaces. To support these surfaces from within the part. So the pattern needs to have a 3rd dimension.
What you describe sounds similar to the variable infill pattern which I think will hug the walls like in your diagram. Until you get near a top surface.
Also the lightning infill I think might hug the walls a bit?
