GregValiant 1,488
Post a project file as well. With the model loaded and the supports and settings the way you want - use the File / Save Project command to create a 3mf project file and post it here.
I was able to “fix” it. I uninstalled Cura and reinstalled it. Then just downloaded one extension. And now it seems to work.
13 hours ago, GregValiant said:Post a project file as well. With the model loaded and the supports and settings the way you want - use the File / Save Project command to create a 3mf project file and post it here.
Hi iam having the same issue can you please elaborate on what you mean by you downloaded “one extension”?
bdsmith1986 0
I’m at work but if anyone wants to look at the files I can upload them when I get off work tonight
