Posted · Print layers are too visible on top areas
Guys i need a help to fix the issue im having. I have an Ended 3 v2 . Recently my prints starting to show visible thick layers on top areas of the print surface. When i checked on cura it shows as the photos attached below. How to fix this issue?
    They are the layer steps.  Like Z seams there is no way around them.
    You can try using "Adaptive Layers" or just lower the layer height.  A piece of fine sandpaper works the best.
