Support blockers can be scaled like any model. Bring one in, size it and configure it however you want, and then multiply it. The new ones will be sized and configured like the original. Then it's a matter of placement. They just need to cover the "overhang" that is usually colored red in the Prepare screen. Note that after all other changes have been mad to a blocker then rotation is last. Once a model has been rotated stretching and scaling are odd because the model origin stays square to the world instead of rotating with the model as it would in CAD.
Those lower two small holes near the bottom edge can be covered by a single blocker since it won't affect anything else. The two top holes (fan mount holes?) will probably need individual blockers because a single wide blocker will probably block the support off the big hole.
I printed this today. You can see that the blockers are different sizes. None of them can interfere with the support that the roof will require or the top of the shallow round pocket on the right.
GregValiant 1,364
