Monitor tab blank when connected to octoprint and moonraker connection plugin is installed
vavaroutsos
Posted · Monitor tab blank when connected to octoprint and moonraker connection plugin is installed
When I connect to an octoprint server with the moonraker connection plugin installed, the monitor tab doesn't work. There is a message that says "In order to monitor you print from Cura, please connect the printer.". There are no errors in the Cura log. If I remove the moonraker plugin, everything works properly.
Should these two pulgins work together? Is this a known issue?
        • 56 replies
        • 29 replies
