I think you should try kisslicer. It's free - it has a nice GUI - it's not too bad. Just make sure you set *ALL* the nozzle widths and line widths everywhere to .4mm. I'm pretty sure you can print the bottom 1/6 with more infill. I'm not certain. Oh - netfabb should be able to do that also.
In cura you could slice it twice - slice it each way, then simply cut and paste. The layer numbers are right there in the gcode comments - there's no reason you can't simply cut and paste - no other editing needed -
oh wait
you need to reset the extrusion in between where the files are sliced together with a G92 - see this:
gr5 2,005
oh wait
http://reprap.org/wiki/G-code#G92:_Set_Position
Something like G92 E853.17234
Which tells the UM that the extruder (e axis) is currently at position 853.17234.
- George
