I'll take a wild guess and say you will end up between 5.5 and 6.5.
Besides the retraction distance have you adjusted the speed? Faster isn't always better.
Your printing temperature makes a difference. Cooler will not string as much.
Within Cura's Travel settings are "Retraction Minimum Travel" and "Max Comb Distance with No Retract". Both need to be set to a distance that is shorter than the distance between the towers but greater than "0". That might be why those 4 models look so identical - maybe there weren't any retractions.
If you haven't done so - turn off Z-hops. They can create a string when the head lifts and the nozzle will pull it to the other tower.
GregValiant 989
