Posted · Cura 5.0 beta 1 and Repetier Server - no plugin directory anymore
I am using Cura 4.1.3 with Repetier Server, and installed 5.0 for testing. But there is no PLGIN directory anmore, into which (in 4.1.3) the Repetier Server files have to be copied. Any ideas hwo Repetier Server can be use in 5.0? I_ve tried to connect via the Octoprint plugin, but this does not work because the API key is recognized being invalid.
Any hints are highly appreciated.
BR,
Thomas
    There;s a `plugins` folder in the configuration folder which you should use. See Help -> Show configuration folder. However, the plugin will need to be specifically updated for use with Cura 5, or it will not work.
