Hi Greg
sorry I didn't see this until today. I thought I'd get n email notification when someone replied.
I didn't actually set the home location. I added the new printed endpoint area.
Also now I just installed Cura 5.
I do notice that in Home position the nozzle is off the bed front left side.
Thank you very much for your reply.
Allen
GregValiant 742
Have you set the Home Offsets in the printer? If you have not then use a decent ruler and:
Auto-Home the printer.
Using the LCD controls:
Move the nozzle up 3mm
Move the nozzle in the X to a point 2.5mm in from the LEFT edge of the build plate.
Move the nozzle in the Y to a point 2.5mm in from the FRONT edge of the build plate.
Drop the Z to "0".
Select "Set Home Offsets" on the LCD.
Select "Save Settings" on the LCD.
Move the nozzle up 3mm again and move the nozzle to X=127.5 and Y=127.5. The nozzle should be at the mid point of the build plate.
The snippet below will work for your startup. The purge line will go along the bottom 12.5mm from the edge PROVIDED you have set the Home Offsets correctly.
;Begin StartUp
M106 S0 ;Layer cooling fan off
G90 ;Switch to absolute positioning
M82 ;Extruder absolute mode
G21 ;metric units
G28 ;Auto-Home all axes
G1 Z15 F600 ;Move up
M140 S{material_bed_temperature_layer_0} ;start to heat the bed
M109 S{material_print_temperature_layer_0} ;heat the hot end and wait for it
M190 S{material_bed_temperature_layer_0} ;wait for the bed just in case it's not up to temp yet
G92 E0 ;Set position of extruder to 0
G0 X5 Y10 F1500 ;Move to start of purge
G0 F600 Z0.3 ;Move Z to 0.3
G1 F1500 X180 E15 ;Extrude a line of filament at 25mm/sec
G1 F1200 Z2 ;Raise Z
G92 E0 ;Set extruder position to zero
G1 F3000 X0 Y0 Z10 ; move back to the left front corner for start of print in case the nozzle oozes
;End of Startup
