GregValiant 980
There are two new settings in the "Walls" section that might be affecting this. "Split Middle Line Threshold" and "Add Middle Line Threshold". The default may be around 95% (it's calculated) so try setting them at 50% and see if it makes a difference.
winkiethecreator 0
Same issue. Played with settings for about an hour before I just went back to 4.13 for right now.
