Posted
(edited)
· Cura 5, how to see layers in preview?
You may have to move the settings floater a bit to the left; the vertical slider is obscured by your settings.
I am working on finishing up the Sidebar GUI plugin for Cura 5.0, which from how you have set up your settings bar seems to be what you want. It puts the settings into a "sidebar" like it used to be in Cura before version 4, and moves some UI elements into what I think is a better place (like the vertical slider to the left of the sidebar). A prerelease can be found here:
On that page, you will see curapackages compatible with different versions of Cura. For Cura 5.0 you will need to download the file ending with `Cura5.0.curapackage`. After downloading that file, drop it onto the 3d viewport in Cura 5.0 as if you were opening a 3d model. You will then be prompted to restart Cura.
Edited by ahoeben
1
ahoeben 1,963
https://github.com/fieldOfView/Cura-SidebarGUIPlugin/releases/tag/v4.3.0-DEV
Edited by ahoebenLink to post
