The "F" parameter in movement lines (usually G0 through G3) are the speed in mm/minute. So if the print speed for a particular extrusion is set at 100mm/sec in Cura then the Gcode line would contain F6000.
The gcode command "M220" is the feedrate multiplier in %. M220 S90 would set the feed rate at 90% of whatever any line in the gcode says. It's the same as adjusting the speed with the knob on the LCD and should be reflected in the "fr" field on the Info screen of the LCD.
GregValiant 1,488
