This is an otherwise well-behaved S5, using the default of 60 on the build plate. This particular print (10mm spacers) is the only one so far that I consider troublesome.
GregValiant 1,351
60 is fine.
If it continues to be a problem there are a couple of custom things you can try.
Put a chamfer on the model. That would hide the elephant's foot.
Go into the gcode and adjust the flow manually with M221 commands. Maybe the first layer at 90%, the second layer at 95% and then the third layer back to M221 S100. Something like that would give it a bit of a taper near the bottom.
You are printing with a skirt for build plate adhesion? For small parts I often use a brim and set the "Brim Distance" to .1 or .15. It makes it easier to break off and leaves less of an edge for post-processing.
GregValiant 1,351
0.2 works for me. I print PLA with the build plate at 50. That might make a difference as well.
If a printer has problems with "Z binding" when it's near the bed then that can look like elephant's foot but it's a mechanical thing and adjusting the Initial Layer Horizontal Expansion doesn't help. That is actually a popular problem on kit printers.
